NGSvensk
Feb 02, 2022Apprentice
V4.6.6.11 Firmware Version and DDNS Remote Access
I have Orbi 850 with V4.6.6.11 firmware and have DDNS setup and I cannot access the Orbi outside of my network. (the app works find though) When I use the DDNS address within my network I can conne...
ekhalil
Feb 03, 2022Master
I have currently v.4.6.75 and DDNS works well. Before that I had v.4.6.3.16 and DDNS also worked well on that formware.
How do you see that DDNS does not work? Do you check this using the "Show Status" button on the DDNS advanced settings? I would recommend to deactivate DDNS in that page, click apply, then activate again and click apply and see if the "Show Status" will show that DDNS has been successfully updated.
Do you use VPN?
NGSvensk
Feb 04, 2022Apprentice
The DNNS is working when I check status and also on wifi by using the name.
I did do the reset as you mentioned and it did not change anything.
Any other ideas?
Thanks
