NGSvensk
Feb 02, 2022Apprentice
V4.6.6.11 Firmware Version and DDNS Remote Access
I have Orbi 850 with V4.6.6.11 firmware and have DDNS setup and I cannot access the Orbi outside of my network. (the app works find though) When I use the DDNS address within my network I can conne...
NGSvensk
Feb 28, 2022Apprentice
Been away from looking at this as my satellite got bricked when the the firmware was downgaded.
I think I know why I cannot access the web accesst to the router remotely because of port 80 being blocked by my ISP I have tried to port forward/trigger but Orbi does not allow me to forward to the Orbi itself to be able to log into it.
Can someone help with how they are able to get remote log in on an Orbi 800 series and if they had to use port forwarding/triggering.
Thanks
NGSvensk
Mar 13, 2022Apprentice
I have had time to try this again and I the only way I can get it to work is to put the the router address on a DMZ which obviously I do not want to do.
After setting up the DDNS and checking the status- it shows registered.
How do I do port forwarding to the router itself or can someone who is using DDNS for remote router access let us know if there are any special settings needed to get web access to the router from outside of your network.
Thanks
