snoyogi2
Jul 15, 2024Tutor
V7.2.6.31_5.0.24 changes guest network password from none to default Password123
After upgrading, a default password was assigned to my guest network with WPA2-PSK [AES], password <Password123>. If I selected Other Networks -> Other... then selected security None, I could stil...
Jul 15, 2024Guru - Experienced User
Password123 is has always been the default password for Orbi Guest networks. Been like that for a while now.
snoyogi2
Jul 21, 2024Tutor
When I reboot the router, it adds a password with WPA2 security when there was none before. It did not exhibit this behavior before upgrade. I have subsequently added a password to my guest network.
- FURRYe38Jul 22, 2024Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
