Timtech
Apr 06, 2025Apprentice
v7.2.7.15 Firmware on RBR 850. Can someone run GRC.com Shields Up
Can you please run Grc.com’s shields up and let me know if you can get full stealth? https://www.grc.com/x/ne.dll?bh0bkyd2 This is the best I can get. I am running Armor. Is that caus...
- Jan 22, 2026
Odd. I tested today and it’s all stealth.
But unsolicited packets failed. A complete 180 from before.
Apr 06, 2025Guru - Experienced User
Is this with nothing else connected to the RBR850 accept for one wired PC and Armor diabled with a single broswer opening to only the GRC web page?
Timtech
It’s with 50 or so items on the guest network.. and 10 or so on the primary WiFi.
I also have two RBS 850s connected.
I do have a host that is also hardwired.
I do have armor enabled, it didn’t change much if I disabled it.
The url was opened on an iPad on the primary WiFi
