Timtech
Apr 06, 2025Apprentice
v7.2.7.15 Firmware on RBR 850. Can someone run GRC.com Shields Up
Can you please run Grc.com’s shields up and let me know if you can get full stealth? https://www.grc.com/x/ne.dll?bh0bkyd2 This is the best I can get. I am running Armor. Is that caus...
Apr 06, 2025Guru - Experienced User
Here is my results from 5 years ago: FW v3.2.15.25
Been a while since we checked this last. 🙄
Timtech
Excellent. Thank you for the quick test and response. I believe a version or two back, I tested and it came up all stealth.
Thanks again.
- FURRYe38Apr 06, 2025Guru - Experienced User
Things change and with the new protection engine feature that has been introd, may change show GRC reports now. Something NG should check into.
- TimtechJun 24, 2025Apprentice
Has anyone else seen any improvement? Mine is still the same.
- FURRYe38Jun 27, 2025Guru - Experienced User
Is this testing with one ethernet connected PC connected to RBR and nothing else connected to the RBR? All devices including RBS should be turned OFF prior to testing to get accurate results.
RBR850 Massive Security Fail - Many ports responding to requests | NETGEAR Communities
What I saw last time I tested and also tested with everything connected results posted there as well.
Also test with Armor disabled to compare results.
