Timtech
Apr 06, 2025Apprentice
v7.2.7.15 Firmware on RBR 850. Can someone run GRC.com Shields Up
Can you please run Grc.com’s shields up and let me know if you can get full stealth? https://www.grc.com/x/ne.dll?bh0bkyd2 This is the best I can get. I am running Armor. Is that caus...
- Jan 22, 2026
Odd. I tested today and it’s all stealth.
But unsolicited packets failed. A complete 180 from before.
Timtech
Jan 23, 2026Apprentice
Found the debug
Basic Information
Firmware Version: V7.2.8.5_5.1.21
Boot Loader Version: V1.0.13
seal: v2.1.10.12-0
armor-bd: v2.2.214.4
spc-circle: v3.32.0.4
guster: v1.0.0.2049
CPU Load: 22.08%
Memory Usage(Used/Total): 390 MB/874 MB
System Uptime: 1 days 12:01:35
Server Information
Router Analytics: PROD
CHP Cloud: PROD
XCloud: PROD
BD Cloud:
Circle Cloud: N/A
AnalyticOptinOptout: Enable
Jan 24, 2026Guru - Experienced User
Ok so I updated my 850 series to v.5 FW today. Power cycled the router. Only had the RBR online with one ethernet connected PC:
GRC Port Authority Report created on UTC: 2026-01-24 at 21:06:54
Results from scan of ports: 0-1055 0
Ports Open 0
Ports Closed
1056 Ports Stealth
1056 Ports Tested ALL PORTS tested were found to be: STEALTH.
TruStealth: PASSED - ALL tested ports were STEALTH, - NO unsolicited packets were received, - NO Ping reply (ICMP Echo) was received.
Protection Engine is seen on the RBRs web page, even on prior FW version:
So this is good and is confirmed fixed. Finally. Should be same for all AX and AXE series models on v.5 FW.
