Fra11
Dec 28, 2020Guide
Valore Frequenza TX Orbi RKB752 e 852
Salve a tutti,
ho una domanda piuttosto tecnica: mi chiedevo qual è la massima velocità ottenibile per connessioni in wifi AC con questi router. Attualmente il valore "frequenza tx" che ottengo connettendo il mac all'orbi RKB752 è di 866Mbps, quale sarebbe con il modello superiore RKB852?
Buone feste e un saluto
in inglese per favore
- Fra11Guide
Sorry I thought it was the italian community! My mistake!
I would like to know what is the AT frequency that I would get connecting a wifi 5 device to an Orbi RKB852. If I connect my iMac to Orbi RKB752 I get "866Mbps". Would I get an higher value if I were using an Orbi RKB852?
I'm talking about this value (in the pic there is the value I got with the previous ISP router)
What is the model of the imac. Older iMacs may not support higher connection rates. Contact Apple support to see what connection rates are supported on you mac. My 2018 mac book pro caps at 1300Mpbs but it's not AX supporting.
- MstrbigMaster
866 is a good speed. Top speed would be determined by many variables. I've seen as high as 976 on my system. My phone is currently connected at 876
