Fra11
Dec 28, 2020Guide
Valore Frequenza TX Orbi RKB752 e 852
Salve a tutti, ho una domanda piuttosto tecnica: mi chiedevo qual è la massima velocità ottenibile per connessioni in wifi AC con questi router. Attualmente il valore "frequenza tx" che ottengo c...
Fra11
Dec 31, 2020Guide
Thank you! So Orbi RKB752 has a 4x4 backhaul while Orbi RKB853 has a 2x2 backhaul? Didnt' knew it.
The speed is very high for me. In the same position via wireless it only reach 500-600 Mbps.
I think it's more attractive for users to read "Up to 4.2 or 6 gbit/s" but in the end this description doesn not make sense. If you start study a little bit you could find it very disappointing. I must confess that at first I bought an Orbi RKB13 thinking that it would be suitabile for connection up to 1.2Gbit/s..
We I first thought about a mesh system I thought I'd have problem with it but Orbi makes everything easy. It's perfect and it's expansive.. but I'm happy. I'm only disappointed by the claim cause I've been fooled by it, at least the first time with Orbi RKB13.
Dec 31, 2020Guru - Experienced User
Both 7 and 8 series have a "Series 7 2.4Ghz Fronthaul: 600 + Series 7 5Ghz Fronthaul: 1200 + 5Ghz Backhaul Series 7 and 8: 2400Mbps" speed rate.
