dstrausser83
Mar 21, 2020Guide
Verizon Fios ONT & AX6000
Ok - I got a weird issue.... I hooked up my Orbi AX6000 directly to the ONT using a Cat7 cable. Pretty rockin you'd think, right? Not so much. Speed is actually SLOWER than if I hooked up th...
- Apr 02, 2020
Please make a new post about your NAS connection issues.
Please mark this thread as solved so others will know.
Something to look into:
Thank you.
dstrausser83
Mar 22, 2020Guide
No double NAT. I've already verified. All ports are open. All game systems say OPEN. My QNAP NAS is perfectly able to connect, do VPN, etc. No issues what so ever.
Everything works BETTER but is SLOWER. It was faster, but not as stable using the Gateway. Wondering if something else.
It's the standard quantum gateway the G1110 or whatever and the standard ONT they use (don't know that model number).
Double NAT is not the issue, I've verified that. No IP conflicts, nothing of those sorts.
Thanks though!
dstrausser83
Mar 22, 2020Guide
I have it "set up" correct for the gateway and the orbi. But I'm thinking I may need/want to tweak a setting in the Orbi that is possibly slowing me down.
I have video working, the Gateway is essentially disabled except for the STBs of the TV service and the Orbi is the main driver.... just working slower. You'd think it'd be faster.
- BanditoMar 22, 2020Luminary
When you say slower, what is slower? Can you provide some numbers so we know how much slower your system is?
Also, is your ONT connection going into the Orbi's WAN port?
- dstrausser83Mar 27, 2020Guide
Sorry, this corona stuff sidetracked me...
So when I do a speedtest in my Orbi in QOS now it is usually below 500 mbps each direction (usually 300 to 400 mbps).
However, when I connect it with the Quantum Gateway first, and then forward all ports and put the Orbi in DMZ, I get usually 700 to 900 mbps on the Orbi speedtest.
It's just weird. I've also completely disconnected the Verizon Quantum Gateway and only ran the Orbi AX6000 and same results, the slower speeds. Could this just be something weird inside the Orbi?
One other "nuance" I noticed... I have a QNAP NAS. Check out the results with the different scenarios:
Quantum Gateway First: Using the same network, I can connect to the QNAP via the web (not internal network)
Orbi Direct Connected to ONT: You cannot connect via the URL. You can ONLY connect on the internal IP address (i.e. 10.0.0.15). BUT, if I am on an external network and I connect to the URL, it works and I connect to the QNAP.
It's almost as if the Orbi detects the loop and blocks it but the Quantum Gateway permitted it.
- ScottD67Mar 28, 2020Star
I'm not sure if I can help you but I do have a very similar configuration. Verizon ONT directly connected to Orbi AX in router mode over CAT6 cable. I also have a gigabit FiOS service and if I run the Orbi QoS test I get 800 down/900 up. I also get 900/900 between all wired devices and my synology NAS that is connected directly to the Orbi. Do you know what model ONT you have? I have a I-211M-L (Alcatel) if that matters.
