dstrausser83
Mar 21, 2020Guide
Verizon Fios ONT & AX6000
Ok - I got a weird issue.... I hooked up my Orbi AX6000 directly to the ONT using a Cat7 cable. Pretty rockin you'd think, right? Not so much. Speed is actually SLOWER than if I hooked up th...
- Apr 02, 2020
Please make a new post about your NAS connection issues.
Please mark this thread as solved so others will know.
Something to look into:
Thank you.
dstrausser83
Mar 22, 2020Guide
I have it "set up" correct for the gateway and the orbi. But I'm thinking I may need/want to tweak a setting in the Orbi that is possibly slowing me down.
I have video working, the Gateway is essentially disabled except for the STBs of the TV service and the Orbi is the main driver.... just working slower. You'd think it'd be faster.
Bandito
Mar 22, 2020Luminary
When you say slower, what is slower? Can you provide some numbers so we know how much slower your system is?
Also, is your ONT connection going into the Orbi's WAN port?
- dstrausser83Mar 27, 2020Guide
Sorry, this corona stuff sidetracked me...
So when I do a speedtest in my Orbi in QOS now it is usually below 500 mbps each direction (usually 300 to 400 mbps).
However, when I connect it with the Quantum Gateway first, and then forward all ports and put the Orbi in DMZ, I get usually 700 to 900 mbps on the Orbi speedtest.
It's just weird. I've also completely disconnected the Verizon Quantum Gateway and only ran the Orbi AX6000 and same results, the slower speeds. Could this just be something weird inside the Orbi?
One other "nuance" I noticed... I have a QNAP NAS. Check out the results with the different scenarios:
Quantum Gateway First: Using the same network, I can connect to the QNAP via the web (not internal network)
Orbi Direct Connected to ONT: You cannot connect via the URL. You can ONLY connect on the internal IP address (i.e. 10.0.0.15). BUT, if I am on an external network and I connect to the URL, it works and I connect to the QNAP.
It's almost as if the Orbi detects the loop and blocks it but the Quantum Gateway permitted it.
- ScottD67Mar 28, 2020Star
I'm not sure if I can help you but I do have a very similar configuration. Verizon ONT directly connected to Orbi AX in router mode over CAT6 cable. I also have a gigabit FiOS service and if I run the Orbi QoS test I get 800 down/900 up. I also get 900/900 between all wired devices and my synology NAS that is connected directly to the Orbi. Do you know what model ONT you have? I have a I-211M-L (Alcatel) if that matters.
- JmartinbMar 29, 2020Aspirant
I'm a FIOS GB customer who just converted from Eero to Orbi RBK852. Using the Orbi mobile app to set things up, it put my RBR850 into router mode with both Orbi devices (router and satellite) and all wirelessly connected devices on the 10 network.
Everything Is working just fine (700-800Mb download and upload speeds) but I cannot connect to my FIOS ONT admin console via the normal IP (192.168.1.1). What do I need to change in my setup to be able to do that? The two networks are obviously routing...what am I missing?
TIA.
