dstrausser83
Mar 21, 2020Guide
Verizon Fios ONT & AX6000
Ok - I got a weird issue.... I hooked up my Orbi AX6000 directly to the ONT using a Cat7 cable. Pretty rockin you'd think, right? Not so much. Speed is actually SLOWER than if I hooked up th...
- Apr 02, 2020
Please make a new post about your NAS connection issues.
Please mark this thread as solved so others will know.
Something to look into:
Thank you.
dstrausser83
Mar 22, 2020Guide
No double NAT. I've already verified. All ports are open. All game systems say OPEN. My QNAP NAS is perfectly able to connect, do VPN, etc. No issues what so ever.
Everything works BETTER but is SLOWER. It was faster, but not as stable using the Gateway. Wondering if something else.
It's the standard quantum gateway the G1110 or whatever and the standard ONT they use (don't know that model number).
Double NAT is not the issue, I've verified that. No IP conflicts, nothing of those sorts.
Thanks though!
Mar 22, 2020Guru - Experienced User
Hopefully your ONT is bridged then. This is a gateway ONT which has a buit in router.
dstrausser83 wrote:No double NAT. I've already verified. All ports are open. All game systems say OPEN. My QNAP NAS is perfectly able to connect, do VPN, etc. No issues what so ever.
Thanks though!
- dstrausser83Mar 28, 2020Guide
If the ONT allows the connection, does that mean that the ONT is bridged? Or could it not being in bridge mode be what the problem was? My Gateway was in bridge mode.
- FURRYe38Mar 28, 2020Guru - Experienced User
Make sure your ONT is fully bridged. I your Orbi RBR is using 10.0.0.# address this means the ONT may not be fully bridged as the RBR is detecting a router front of it and the ONT maybe using the same IP address string, 192.168.1.1 which causes the RBR to change to someting else, like 10.0.0.15.
What happens if you configure the ONT for router mode and then configure the RBR for AP mode. Remove the DMZ/IP Pass thru on the modem for ap mode on the RBR.
