dstrausser83
Mar 21, 2020Guide
Verizon Fios ONT & AX6000
Ok - I got a weird issue.... I hooked up my Orbi AX6000 directly to the ONT using a Cat7 cable. Pretty rockin you'd think, right? Not so much. Speed is actually SLOWER than if I hooked up th...
- Apr 02, 2020
Please make a new post about your NAS connection issues.
Please mark this thread as solved so others will know.
Something to look into:
Thank you.
dstrausser83
Apr 02, 2020Guide
Hey all, so with my situation, it all seems to be fixed... Good info there and basically I set mine up essentially how that link was posted by accident it seems like lol
No double NAT. TV STB connected and run fine.
I do have an odd issue though. I run a QNAP NAS at my house. When I ran through the VZ Quantum Gateway, connectivity was perfect. No issue. Now with the Orbi, even using UPnP or doing manual port fowrads, I can't get ports 8081 or 80 to work. To prove it is not an issue because of how I currently have the network setup, I completely disconnected the VZ Quantum Gateway and it has no impact on the results.Same thing.
I know how to port forward and all that fun stuff, but for some reason these ports won't open and forward. Verizon has confirmed all ports are open.
What am I doing wrong here?
Again, don't consider double nat or any issues with how I am running it because like I stated, I can have the Quantum Gateway completely disconnected from the network and I have this issue. It seems that when I use the Verizon Gateway though as the primary driver and set those ports to forward, they actually do forward. Opening the ports in the Orbi doesn't seem to be working.
What ideas do ya'll have?
Thanks
Apr 02, 2020Guru - Experienced User
Thank you.
- dstrausser83Apr 02, 2020Guide
Will do. Thanks.
- FURRYe38Apr 02, 2020Guru - Experienced User
Enjoy.
