cabchop
Jan 11, 2021Tutor
Verizon GB Fios...expectations for Orbi WIFI speeds?
Hello. I have the latest firmware for my RBR850. My current Verizon fios plan is the 1 gig up/down plan. I am not using the provided G3100 router from FIOS. I have the ONT plugged directly int...
Jan 11, 2021Guru - Experienced User
Most iphones and WiFi 5 devices will max out at around 400-500Mbps due to the antenna design, 2x2. Even my 12 Max gets around 400 to 500ish speeds. I have a Asus GT-AX11000 router that is 4x4 that I can use as a wireless client and it can get 900Mpbs speeds. Connection rate between the Orbi AX and the Asus is around 1800Mpbs as well. Something my 12 Max phone doesn't get.
