msinex
Apr 16, 2020Apprentice
Very Brief Internet Connection Issues
I actually have the AX6000 Orbi mesh system and couldn't find it on the list, but I think it is the same as the RBK53. I have recently installed the AX6000 system system and been very happy with t...
Bandito
Apr 16, 2020Luminary
Furry,
This sounds like a potential issue with the RTS/CTS settings, no?
This last firmware set the threshold down to 64, where previously it was 2347. Check and adjust if necessary.
msinex
Apr 19, 2020Apprentice
Thanks, I will give this a try and see if it works and report back. If it doesn't work, I will try a reset from scratch.
