msinex
Apr 16, 2020Apprentice
Very Brief Internet Connection Issues
I actually have the AX6000 Orbi mesh system and couldn't find it on the list, but I think it is the same as the RBK53. I have recently installed the AX6000 system system and been very happy with t...
Apr 20, 2020Guru - Experienced User
Does this happen with different browsers?
I would give a factory reset on the RBR and power OFF the ISP modem for 30 seconds then back on and walk thru the setup wizard a try.
msinex
Apr 21, 2020Apprentice
I will work on that on my day off later in the week.
This has happened on a Win10 machine on both Chrome and Firefox, and my work Win10 machine with Chrome, and then it does it all the time on the DakBoard set up which is actually a Raspberry pi machine.
On the Raspberry pi, it gives an error around a "name resolution" issue; but then when I reload it immediately finds the webpage again. It gave me another "no internet" connection error when I was power cycling the router and I know there wasn't any internet connection. Is there some sort of setting on the router that would potentially cause a naming issue?
- Mikey94025Apr 21, 2020Hero
I actually have seen something similar in the past with the primary Windows 10 laptop I use and my Chrome browser. I briefly see an error in the browser but then it often refreshes immediately. I used to use Google DNS and switched it back to my ISP's DNS entries, but that didn't seem to make a difference.
I haven't seen it reappear in the past few days after repairing my Wireless connection. This is what I did:
- Right-click on the network toolbar icon and select Open Network & Internet Settings
- Change adapter options
- Right-click on the Wi-Fi connection, select Diagnose
