msinex
Apr 16, 2020Apprentice
Very Brief Internet Connection Issues
I actually have the AX6000 Orbi mesh system and couldn't find it on the list, but I think it is the same as the RBK53. I have recently installed the AX6000 system system and been very happy with t...
Apr 20, 2020Guru - Experienced User
Does this happen with different browsers?
I would give a factory reset on the RBR and power OFF the ISP modem for 30 seconds then back on and walk thru the setup wizard a try.
msinex
Apr 23, 2020Apprentice
I have time set aside on Saturday to reset and rebuild the router, but had a question in the interim. Someone else I spoke to in the real world indicated this could be a proxy server setting issue with the Orbi. The error I'm getting on my work laptop sometimes is that windows could not automatically detect the networks proxsy settings. I hit refresh on the site then and it almost always seems to work. This is a windows 10 machine using either internet explorer or chrome (same error whether ethernet connection or wireless).
- FURRYe38Apr 23, 2020Guru - Experienced User
Try looking at Control Panel/Internet Options/Connections tab/Lan Setting button"
The Automatically dectect settings can be either checked or unchecked. I have kept this uncheck since the days of XP. I was told a long time ago that this setting can cause varied problems.
msinex wrote:I have time set aside on Saturday to reset and rebuild the router, but had a question in the interim. Someone else I spoke to in the real world indicated this could be a proxy server setting issue with the Orbi. The error I'm getting on my work laptop sometimes is that windows could not automatically detect the networks proxsy settings. I hit refresh on the site then and it almost always seems to work. This is a windows 10 machine using either internet explorer or chrome (same error whether ethernet connection or wireless).
