egasxam
Oct 23, 2022Follower
Very Expensive Orbi Rout RBR850 - several devices failing to connect
Had this product for about 18 months. Now finding devices failing to connect to the wifi on a regular basis. Unfortunately the paltry 90 days support has now expired - atrocious support from Netgear!...
Oct 23, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What devices do you have all connected?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
