egasxam
Oct 23, 2022Follower
Very Expensive Orbi Rout RBR850 - several devices failing to connect
Had this product for about 18 months. Now finding devices failing to connect to the wifi on a regular basis. Unfortunately the paltry 90 days support has now expired - atrocious support from Netgear!...
CrimpOn
Oct 24, 2022Guru - Experienced User
Would be helpful to know what sort of devices are failing to connect.
- Did these devices connect correctly in the past?
- What is the indication that devices are not connecting?
- An error message on the device?
- No longer appearing on smartphone applications?
