Mikey94025
Dec 12, 2021Hero
Very pleased with Netgear RBKE963 (AXE11000) and its 4 radios
I've had my Netgear RBKE963 (AXE11000) system for two days now and it's been working very well. It replaced my Orbi AX (RBK852) system. I was also running my older Orbi AC (RBK50) system for wirele...
TC_in_Montana
Dec 13, 2021Virtuoso
Mikey94025 wrote:I've had my Netgear RBKE963 (AXE11000) system for two days now and it's been working very well. It replaced my Orbi AX (RBK852) system. I was also running my older Orbi AC (RBK50) system for wireless compatibility reasons and troublesome devices. The new AXE system has been great and I've been able to shutdown all the other routers.
<snipped out>The only issue I've noticed so far with my AX system is a minor one - My "mynetgear.com" Dynamic DNS config using Netgear's No-IP isn't working. The status is always like: "Update failed at 01:08PM,12/11/2021 The service provider is not reachable." I believe I entered my credentials properly and I can login successfully with them at the Netgear-branded website. It's not critical so I'll just wait and see if a future firmware update fixes the problem.
Happy you are pleased with the RBKE963!
I'm using the Dynamic DNS configuration on my RBKE963, but not the mynetgear one. I am using my DDNS from NOIP and it is working perfectly and without any issues - so thinking it is not necessarily a firmware issue, but maybe something with mynetgear.com
Mikey94025
Dec 13, 2021Hero
Thanks for that. I switched to a No-IP login and a new hostname and it does work fine. So my previous DDNS problem with my AXE router is specific to mynetgear.com updating.
- dcincaDec 16, 2021Apprentice
Yea, it's mynetgear.com's problem.
It stopped updating the IP around Dec. 7/8.
