Janeksty
Sep 10, 2022Aspirant
Very strange issue with AX4200 Tri Band Orbi
Hi everyone. First time poster and I have an issue that is frankly weird (well i think it is anyway). My Orbi AX4200 (1 satelite) is working very well for my PC, gaming consoles etc. The issu...
Sep 11, 2022Guru - Experienced User
and no other device has issues?
Just the one device?
Have you tired disabling AX? maybe the tablet has an issue with AX.
- ekhalilSep 11, 2022MasterSuch strange issues can be caused by double routers. What is the model of the ISP modem/router to which the Orbi router is connected please?
- JanekstySep 12, 2022Aspirant
It is a TPLink AC 1600. The wifi part is turned off.
Issues only started recently, it has worked before.
- ekhalilSep 12, 2022MasterIt’s ot enough to just turn the ISP router’s wifi off, it’s still doing routing functions. You have either to set the ISP router into bridge/passthrough mode or change Orbi to AP mode.
