Janeksty
Sep 10, 2022Aspirant
Very strange issue with AX4200 Tri Band Orbi
Hi everyone. First time poster and I have an issue that is frankly weird (well i think it is anyway). My Orbi AX4200 (1 satelite) is working very well for my PC, gaming consoles etc. The issu...
Sep 11, 2022Guru - Experienced User
and no other device has issues?
Just the one device?
Have you tired disabling AX? maybe the tablet has an issue with AX.
ekhalil
Sep 11, 2022Master
Such strange issues can be caused by double routers. What is the model of the ISP modem/router to which the Orbi router is connected please?
- JanekstySep 12, 2022Aspirant
It is a TPLink AC 1600. The wifi part is turned off.
Issues only started recently, it has worked before.
- ekhalilSep 12, 2022MasterIt’s ot enough to just turn the ISP router’s wifi off, it’s still doing routing functions. You have either to set the ISP router into bridge/passthrough mode or change Orbi to AP mode.
