psheld
Aug 30, 2023Tutor
Video call jitters / latency
My config Cable modem Router RBR750 / 4.6.14.3 2x Satellites, both RBS750 / 4.6.9.11 Cat5 backhaul WMM enabled for both bands CTS/RTS 64 for both bands Distance of iMac from satellite — 7m Co...
psheld
Sep 11, 2023Tutor
Just updated the firmware on both satellites and then the router to 7.2.6.21 ... which is a weirdly big leap in numbering from the previous stable firmware (4.6).
I've just run a Waveform buffer bloat test on my Macbook-2metre-cat6satellite and it still gets a C grade. No experience yet of external calls, but will report back mid-week with a report.
In the meantime, if anyone has any other things I can try to fix this problem, please don't wait until then!
Cheers.
- FURRYe38Sep 11, 2023Guru - Experienced User
I recommend a power OFF of the Orbi system and ISP modem for 1 minute then back ON with the modem first then Orbi system. Test for the video call problems.
If problems persist, factory reset and setup from scratch. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System < prefer using this method.I've been using this version for a while and have not seen any video issues in Zoom meetings I have had nor phone calls. I asked some others to test with and without SIP ALG enabled and saw now issues here either.
You may want to check your devices and PCs for issues.
- psheldSep 11, 2023Tutor
Thanks FURRYe38.
I may have time on Wednesday to give this a go.
I can respond I think to the alternative you raise: "You may want to check your devices and PCs for issues."
With a wired connection to either satellite, all video calls from any device work a treat and Waveform gives an A grade. It's only wireless that has the problem, and I think it's very much more likely that the corresponding problem lies in one product — the Orbi — than all the others separately.Thanks again and I'll be back here as soon as I can.
Bufferbloat testing is mostly for ethernet connections. Due to wireless having many variables and factors, would not give good or accurate test results for wireless connections.
- psheldSep 28, 2023Tutor
Life got in the way. But at the moment it looks like I might have the time to follow your instructions FURRYe38 this coming weekend.
I think I'm also going to try a range extender for the iMac-concretewall-cat5satellite combo because it really is a crappy connection as it stands. Miserable. Would the following do the job? ...- FURRYe38Sep 28, 2023Guru - Experienced User
Something to try of course.
