artiprod
Apr 06, 2022Aspirant
Virgin Router 4 and Orbi Mesh 6 system
Hi I have Virgin 1gig Broadband and Virgin Router 4 I purchased an Orbi Duel Band Mesh WiFi 6 system RBK353 The VM Router has been put into Modem only status. I have filled the instructions...
Apr 06, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- artiprodApr 06, 2022Aspirant
thank you for your reply, i will do as you suggest tomorrow and report on the result.
