artiprod
Apr 06, 2022Aspirant
Virgin Router 4 and Orbi Mesh 6 system
Hi I have Virgin 1gig Broadband and Virgin Router 4 I purchased an Orbi Duel Band Mesh WiFi 6 system RBK353 The VM Router has been put into Modem only status. I have filled the instructions...
Apr 06, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
artiprod
thank you for your reply, i will do as you suggest tomorrow and report on the result.
