ASysBmq
Apr 16, 2025Aspirant
VLAN question about RBK762S
Hello, I wish to buy a Wifi 6 router with mesh ability between the router and one satelite. But I also need the router to be able to use VLAN tagging as per 802.1q norm (the wifi VLAN will be on ...
- Apr 16, 2025
The 760 series is not a Pro version of Orbi, it's home version and home versions do not support VLAN configurations for WiFi. Something Orbi Pro versions did. Though they are not made anymore.
