Paul1954
Mar 16, 2024Aspirant
VPN connection with Orbi RBR350
How can I determine if my router is capable or supports VPN products please
Paul1954
Hi
Thanks
for the info
I have enabled the VN on the orbi router with open vpn
But cannot seam to get surfshark to operate directly with the router so all devices on the router go through this VPN supplier
Any thoughts ?
Paul
CrimpOn
Mar 16, 2024Guru - Experienced User
Please read message 2 above:
There are some routers (not from Netgear) which have the capability to make the router itself into a VPN client that encrypts the communication from every device on the network into a tunnel that connects with one of those VPN hosts on the internet. Netgear routers do not support that capability.
