SpudMunky
Oct 08, 2023Aspirant
VPN host setup on RBK960 with BT SmartHub (UK)
Hi, Can anyone tell me how to configure the VPN host service to run on my RBK960 when connected through (or with) a BT SmartHub 2 router in the UK? I need to keep the SmartHub 2 router in the n...
- Oct 08, 2023
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
SpudMunky wrote:
Hi,
I need to keep the SmartHub 2 router in the network to provide my BT Digital Voice telephone service. I need to know how to connect everything up and configure everything to allow use of the VPN host service on the RBK960.
Can anyone tell me how to connect everything? i.e. to use the VPN host service do I have to if I use the RBK960 as my main router, or can I somehow continue to use the BT SmartHub as my main router? If I can/must connect the BT SmartHub as a device on the network, will our BT Digital Voice service still work through it normally?
Many thanks
schumaku
Oct 08, 2023Guru - Experienced User
By rule of thumb, you need to operate your BT router (to keep support for BT Digital Voice) as a router, and configure a full DMZ where the RBR960 router will be connected. Don't forget to add an address reservation for the intermediate network and IP subnet for the Netgear router, and NAT forward the port 1194/UDP to the Netgear router WAN (Internet adapter), effectively operating on a private IP subnet.
Be ready to take rants in the community about double NAT.
To my knowledge - keep in mind I'm from Switzerland and far away from a BT Internet connection -
both the Smart Hub and the Business Smart Hub 2: BT Digital Voice are not compatible with the hub when in bridging mode, so terminating the Internet connection direct on the Netgear Router (any) isn't possible.
Better consult with a community with specific BT Internet knowledge, like the BT Community for example, in case you don't get appropriate information here.
-Kurt
