vblack
Aug 26, 2022Star
VPN ip address change
Hello. I have two systems RBRE960 and RBR850. Both activated VPN service. The problem is that they both have save VPN IP/subnet 192.168.254.1, so I could not connect to both of them at the same time...
ekhalil
Aug 29, 2022Master
Why don't you change the IP range in one of the systems to something else, e.g. 10.0.0.x. ?
vblack
Aug 29, 2022Star
Systems had different ranges
192.168.5.0 and 192.168.10.0, but vpn on both 192.168.254.0. I will try to change dramatically to 10.10.x but I highly doubt it will change VPN ip
- ekhalilAug 29, 2022MasterIt should
- CrimpOnAug 29, 2022Guru - Experienced User
Was that a typo? (192.168.254.0 vs. 192.168.254.1)
Netgear changed IP subnets around from the original product line, where every device was in one subnet (primary & guest) and VPN clients were assigned from the next higher subnet starting at 2 (the router takes 1). The AX line introduced a separate subnet for the guest network. Are there even more subnets in the 960 product line? (IoT? 6E?) I could see an engineer wondering, "Where do I put VPN if (a) guest network is enabled, or (b) guest network is not enabled?"
Just an idle question: When more than one VPN connection is active, do the IP addresses go "up", i.e. 192.168.254.2, then 3, then 4?
- ekhalilAug 29, 2022MasterYes, 192.168.254.2, then 3, then 4
- vblackSep 11, 2022Star
Well it is not.
I have changed RBRE960 router lan to 10.10.10.0/24 and VPN address still 192.168.254.2
While second router RBR850 lan 192.168.5.0/24 with VPN address also 192.168.254.2
Am I missing something?
Thank you.
- ekhalilSep 11, 2022MasterOk, then seems that 192.168.254.x is hard coded in Orbi.
Previously when the CLI interface (telnet was open in Orbi we could easily change this, but unfortunately now I don’t think there is anything we can do.
