vblack
Aug 26, 2022Star
VPN ip address change
Hello. I have two systems RBRE960 and RBR850. Both activated VPN service. The problem is that they both have save VPN IP/subnet 192.168.254.1, so I could not connect to both of them at the same time...
ekhalil
Sep 11, 2022Master
Ok, then seems that 192.168.254.x is hard coded in Orbi.
Previously when the CLI interface (telnet was open in Orbi we could easily change this, but unfortunately now I don’t think there is anything we can do.
CrimpOn
Sep 11, 2022Guru - Experienced User
What parameter would one set using a command line interface (telnet) to manage the IP subnet assigned to VPN connections?
- Idle curiosity. Would like to see what happens when I try it on a test system.
- I have heard rumors of a way to enable telnet on the AX products This might prove to be a solution to this specific circumstance.
- ekhalilSep 11, 2022MasterOnly the following parameter needs to be changed:
openvpn_tun_ipaddr=192.168.254.1- CrimpOnSep 11, 2022Guru - Experienced User
A puzzle. I do not find a parameter openvpn_tun_ipaddr
on my RBR50. Is this parameter unique to the AX models?
.... Or, am I just not looking for it correctly?
- ekhalilSep 11, 2022MasterYes, this is only in AX models. In the AC models VPN don’t give the 192.168.254.x addresses. Completely different
