vblack
Aug 26, 2022Star
VPN ip address change
Hello. I have two systems RBRE960 and RBR850. Both activated VPN service. The problem is that they both have save VPN IP/subnet 192.168.254.1, so I could not connect to both of them at the same time...
vblack
Sep 11, 2022Star
Well it is not.
I have changed RBRE960 router lan to 10.10.10.0/24 and VPN address still 192.168.254.2
While second router RBR850 lan 192.168.5.0/24 with VPN address also 192.168.254.2
Am I missing something?
Thank you.
vblack
Oct 06, 2022Star
So, as an update - I have official answer that VPN address could not be changed at the moment on AX Orbi.
They suggested to create feature request, so I did:
