5pyrals
Nov 15, 2024Aspirant
VPN Issue on RBR750
I am using an RBR750 v.31 firmware and enabled the VPN last night and downloaded the config file. I have been through the TAP/TUN issues and modified the config file on the client. I am currently s...
CrimpOn
Nov 15, 2024Guru - Experienced User
What is the client? (Windows, smartphone, etc.)
Is the config file now set to tap or tun? I have an RBR750 with VPN enabled and find that the tun connection is the only one that works for me with Windows.
5pyrals
Nov 18, 2024Aspirant
I am testing with a Windows 11 machine. The config is set to TUN. I went through it again and there are really no settings to adjust beyond port. I wish they made it a lot more user configurable. I am used to Fortinet and Sonicwall firewalls (this replaced a Sonciwall).
