david42
Mar 06, 2022Aspirant
VPN server does not work when Guest Network is enabled
Model: RBR850 Problem: Clients connected to the VPN are unable to access devices on the LAN when the Guest WiFi network is enabled. Configuration: LAN IP range: 192.168.1.X (my choice) Gue...
Mar 06, 2022Guru - Experienced User
david42
Orbit firmware: V4.6.3.16_2.0.51
Orbit connected to TP-Link VR1600v, which has routing functions disabled and is purely used as a modem (no double NAT).
- FURRYe38Mar 06, 2022Guru - Experienced User
Do you see any of these items list for the VPN? "Clients will use this VPN connection to access" or "All sites on the Internet & Home Network"
Might give newer FW a try as well:
- david42Mar 06, 2022AspirantFor the "Clients will use this VPN connection to access", Ive tried both "Auto" and "Home network only", they both have the same problem.
I checked for updated firmware in the orbi web UI and it said no newer firmware was available. Is this a beta/otherwise? Or is the orbi failing to detect new firmware?- FURRYe38Mar 06, 2022Guru - Experienced User
This version hasn't been put up on the auto update services as of yet so manual installation is needed.
Review the notes I posted. This is official release.
