david42
Mar 06, 2022Aspirant
VPN server does not work when Guest Network is enabled
Model: RBR850 Problem: Clients connected to the VPN are unable to access devices on the LAN when the Guest WiFi network is enabled. Configuration: LAN IP range: 192.168.1.X (my choice) Gue...
david42
For the "Clients will use this VPN connection to access", Ive tried both "Auto" and "Home network only", they both have the same problem.
I checked for updated firmware in the orbi web UI and it said no newer firmware was available. Is this a beta/otherwise? Or is the orbi failing to detect new firmware?
Mar 06, 2022Guru - Experienced User
This version hasn't been put up on the auto update services as of yet so manual installation is needed.
Review the notes I posted. This is official release.
