ant
Sep 21, 2021Prodigy
W10 unable 2 reconnect to my 12 yrs. old Linux (Debian Jessie v8) PC's Samba after rebooting Orbi.
This is with network cables with static IP addresses. I have to reboot my 64-bit W10 Pro. PC to make it work again. I am have all the updates for everything including Orbi RBK753S-100NAS router's. ...
titaniumrx8
Sep 21, 2021Apprentice
ant wrote:This is with network cables with static IP addresses. I have to reboot my 64-bit W10 Pro. PC to make it work again. I am have all the updates for everything including Orbi RBK753S-100NAS router's.
Does anyone have this problem too and know how to fix it?
Thank you for reading and hopefully answering soon. :)
Can you ping the Linux box from the W10 PC?
If you can ping it then the issue is probably a windows setting ie network discovery or UPNP.
ant
Sep 21, 2021Prodigy
Yes. Even SSH2 still connects and works. It's just file sharing (Samba) stops working after the router is rebooted.
- titaniumrx8Sep 22, 2021Apprenticeant
I use a different linux distro but a recent linux update killed Samba for me also. I had to change the SMB version on the server to SMB3 which is the minimum required for W10. For some reason the linux update reverted to SMB1.
