ant
Sep 21, 2021Prodigy
W10 unable 2 reconnect to my 12 yrs. old Linux (Debian Jessie v8) PC's Samba after rebooting Orbi.
This is with network cables with static IP addresses. I have to reboot my 64-bit W10 Pro. PC to make it work again. I am have all the updates for everything including Orbi RBK753S-100NAS router's. ...
ant
Sep 21, 2021Prodigy
titaniumrx8 wrote:
ant wrote:This is with network cables with static IP addresses. I have to reboot my 64-bit W10 Pro. PC to make it work again. I am have all the updates for everything including Orbi RBK753S-100NAS router's.
Does anyone have this problem too and know how to fix it?
Thank you for reading and hopefully answering soon. :)
Can you ping the Linux box from the W10 PC?
If you can ping it then the issue is probably a windows setting ie network discovery or UPNP.
Yes. Even SSH2 still connects and works. It's just file sharing (Samba) stops working after the router is rebooted.
titaniumrx8
Sep 22, 2021Apprentice
ant
I use a different linux distro but a recent linux update killed Samba for me also. I had to change the SMB version on the server to SMB3 which is the minimum required for W10. For some reason the linux update reverted to SMB1.
