DFTopping
Nov 11, 2019Aspirant
Wall Mount for Orbi WiFi 6 System AX6000 (RBK852)
I just ordered the Orbi WiFi 6 System AX6000 (RBK852) from Amazon.Com (delivery date pending). I would like to wall mount one of the units. Can anyone recommend a wall mount bracket? Does it fit into...
Nsiddons
Nov 12, 2019Apprentice
https://community.netgear.com/t5/Orbi-AX/Mounting-Bracket/m-p/1821840#M306
I had a similar post myself. There are 2 screw holes on the bottom of wash unit. And I bought 2 3or 4in L-Brackets from Home Depot. I’ll try to go back to the job site and get some pics.
DFTopping
Nov 23, 2019Aspirant
Thanks for the great idea. I will give that a try. Do you know what size the screws are? I just got my Orbi and would love to try this idea. Thank you!
Dave
- ekhalilNov 23, 2019Master
Please check this out:
https://community.netgear.com/t5/Orbi-AX/Mounting-Bracket/m-p/1822117/highlight/true#M314
- ZultanJan 23, 2020Star
Try this link:
These work very well and are designed for the new Orbi RBR 850 Router and Satellites.
