dbrb2
Jan 08, 2022Apprentice
WAN / LAN throughput on RBR750 when using PPPoE
I am looking at using an RBK753 on my home network, which is a kit consisting of an RBR750 router and 2 satelite nodes. The house has 1Gbps down, 300 up, provided over fibre, which I access via ...
dbrb2
Jan 09, 2022Apprentice
Thanks - yes, looking at the various posts the bottleneck seems to come when using PPPoE. There is quite a lot of overhead to routing close to 1000 Mbps from WAN to LAN, and it seems some hw/fw combinations are not capable of doing that
Worst case I can return the kit after testing if it is a problem but it would be neater to find out beforer purchasing if threre will be a proiblem if at all possible :-)
Jan 09, 2022Guru - Experienced User
Historically PPPoE connections have been problematic for users.
Yes, can definately try something out to see if it works.
