dstrausser83
Mar 21, 2020Guide
WAN Aggregation
Hi. I got two questions... I have Verizon Fios (1/GBS DL & UL). Will Wan Aggregation do anything for me? Should I activate it and if I do, what are the benefits and what should I do? I've only fo...
Mar 21, 2020Guru - Experienced User
You can if your ISP modem also supports LAG.
https://en.wikipedia.org/wiki/Link_aggregation
Leave it enabled unless you have problems. Mostly SIP helps in some VoIP processing.
dstrausser83
Mar 21, 2020Guide
Thank you!
- FURRYe38Mar 22, 2020Guru - Experienced User
:smileywink:
