dstrausser83
Mar 21, 2020Guide
WAN Aggregation
Hi. I got two questions... I have Verizon Fios (1/GBS DL & UL). Will Wan Aggregation do anything for me? Should I activate it and if I do, what are the benefits and what should I do? I've only fo...
ekhalil
Mar 23, 2020Master
dstrausser83 wrote:......
Do you have 2 physical links from Verizon? Link aggregation is needed if you have multiple internet links and you want to combine them to improve the throughput.
- dstrausser83Mar 28, 2020Guide
No, I only got 1. Is it possible to get two? :)
- ekhalilMar 28, 2020Master
dstrausser83 wrote:No, I only got 1. Is it possible to get two? :)
Please check with your ISP if they can provide you with 2 links. Link aggregation is a function to use with multiple internet links to improve the throughput.
