dstrausser83
Mar 21, 2020Guide
WAN Aggregation
Hi. I got two questions... I have Verizon Fios (1/GBS DL & UL). Will Wan Aggregation do anything for me? Should I activate it and if I do, what are the benefits and what should I do? I've only fo...
Bandito
Mar 28, 2020Luminary
I'm surprised that no one has said this, but in your situation, LAN aggregation will buy you nothing.
You have 1Gbps service and 1Gps LAN ports, so everything matches up perfectly to support your current Internet service speed.
If in the future, your ISP supports faster service, such as 2Gbps, then you would need LAN aggregation to take advantage of any speed beyond 1Gbps up to the maximum of 2.5Gbps supported by the Orbi's aggregation option.
dstrausser83
Apr 02, 2020Guide
Bandito, perfect. That is what I was trying to figure out and understand. Will it make a difference or not. That is the best answer I was looking for. THank you!
