StoneAge-BC
Oct 05, 2023Aspirant
WAN IP address changed by ISP
Issue: Every time my network drops, the power goes out, or there is any hiccup in the signal, my modem has to be re-provisioned from the Spectrum side to reconnect, AND I have to reset the Orbi to fa...
CrimpOn
Oct 05, 2023Guru - Experienced User
StoneAge-BC wrote:
Issue: Every time my network drops, the power goes out, or there is any hiccup in the signal, my modem has to be re-provisioned from the Spectrum side to reconnect, AND I have to reset the Orbi to factory setting and do a whole new reset.
This is not acceptable. I have Spectrum. When Edison favors us with a power outage, Spectrum service resumes immediately when power is restored. It is correct that Spectrum provides residential customers with a Dynamic IP address, but Spectrum changes the IP address very seldom (months and months between changes). Anyway, a change in IP address does not affect service unless the router is forwarding ports or using OpenVPN. In that case, the protocol is to enroll in a DDNS service so that the router will automatically update the IP address associated with the customer URLs.
