2JA
May 31, 2021Follower
want to connect satellites by wire (wifi connection not possible)
RBK753 — Système Orbi WiFi 6 AX4200 Hello, Got in replacement of my RBK50 the RBK 753 Wifi6. My old system was wired and everything was fine. While replacing the system, I wanted yo conne...
Jun 07, 2021Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
2JA wrote:RBK753 — Système Orbi WiFi 6 AX4200
Hello,
While replacing the system, I wanted yo connect the sattelites by cable but it doesn't work.
The sattelites want to connect by Wifi on the main Orbi router, wich isn't possible.
i tried everything and can't find the solution
What should I do.
Thank's in advance
