semiluddite
Dec 11, 2023Tutor
Websites Blocked
Hi. I have the Orbi RBR750 and all of a sudden, a month ago, some websites would not work. I noticed that it was only some e-commerce websites that did not work. I checked online and I found the f...
- Dec 21, 2023
FIXED! I got my Internet provider to change the modem and then after a factory reset of the Orbi router, all of the websites are now accessible!!! Even though they denied that would fix the problem. Ha!
Thank you everyone for your help!
Dec 12, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is Armor or Smart Parental controls enabled on the RBR?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Or use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
- semiludditeDec 17, 2023Tutor
I followed these steps but the websites are still blocked.
- michaelkenwardDec 17, 2023Guru - Experienced User
Did that include a different browser?
Yes, different browsers on desktop, on iPad, and on Android smartphones.
