Giuseppe10
Jan 07, 2021Aspirant
Weird Orbi AX6000 network map
I have a Orbi AX6000 system. Bought the 2 pack and then when they released the single router I bought one. RBR/ 2 RBS 850. My system seems to work fine but sometimes my wife's iphone's wifi has tr...
RafS
Jan 08, 2021Apprentice
I thought I was the only one with this issue but in my case, my Home Pod shows up as a satellite..
- FURRYe38Jan 08, 2021Guru - Experienced User
Got a screen shot of this?
- RafSJan 08, 2021Apprentice
I will when I get home from work.
- Giuseppe10Jan 08, 2021AspirantDoes it make your homepods have problems??? My phone never has any WiFi trouble but my wife’s does sometimes and hers is the one in the picture. We both have iPhone 12 pro
- RafSJan 09, 2021Apprentice
I don't use the HomePod enough to actually know if it's having issues but here's the screenshot of how the setup looked like with one RBR and one RBS and one HomePod as a satellite
It did finally bug me enough yesterday that I ended up doing a reset on the system and started from scratch and that fixed the issue for now but then nothing would connect to the satellite for some reason, even though it stayed in the same location it has been for the last 12 months without issues (at least major ones). A power reset fixed that but one more time I'm forced to reset and start from scratch and it will be done, just with a different brand mesh system.
- FURRYe38Jan 09, 2021Guru - Experienced User
Distance is key between the RBR and RBS.
It's up to wifi devies ti pick and choose where they connect too, not Orbi. If you have both RBR and RBR synced up and working, you can do a reboot of the RBR and this may force some devices to connect to the RBS.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Good Luck.
