MichaelDietrich
Aug 02, 2022Follower
Well in the end neither somfy Tahoma, nor Nuki 3.0
Well in the end neither somfy Tahoma, nor Nuki 3.0 with integrated Wifi nor Netatmo do connect to the iOT Network of the RBRE960. All say "wrong password", though computers and mobiles do connect wi...
Aug 02, 2022Guru - Experienced User
How do you have the IoT broadcast configured?
How do you have the IoT security set for on the RBR?
If you disable WPA on the IoT broadcast temporarily, do your devices connect then? Re-enable WPA2 after testing.
