mingcyu's avatar
mingcyu
What’s the expected WiFi speed for RBR 750
I have a RBR750 and ATT 1000. Recent pings have gone up to 20 ms. Using firmware v7.2.6.31 My top download speed even next to the router is 700 but I’m usually at 285-300 throughout the house using...
  • mingcyu's avatar
    mingcyu
    Nov 16, 2024
    So after performing the reset I started tinkering with the server destination in Speedtest. Knowing that speed is related to distance I changed test servers to a closer one and I can achieve rates of 700. This gives me confidence that the problem isn’t the router but with my testing methodology.
    thanks to all who helped. I think the factory reset still a good best practice.
    if things change I might revert back to the .21
