MarcB376
Jan 06, 2022Aspirant
What A Set Up = Orbi AX1800 RBK353
So i have just managed to by my first wifi 6 Mesh set up. I have purchased a AX1800 WiFi Mesh System (RBK353) Orbi Dual-Band WiFi 6 Mesh System, 1.8Gbps, Router + 2 Satellites. After almost 5 ho...
Jan 06, 2022Guru - Experienced User
What happens if you bring the RBS to the same room as the RBR and try to press the sync button on the RBS then soon after press the sync button on the RBR. Turn OFF the other RBS before trying this.
Reivew the RBRs Connected Devices page to see if the 2nd RBS connects or not.
Possible the RBS did not get the FW update that the RBR got and could be causing this...RBS needs to be on same firmware version as whats loaded on the RBR.
