TheHolmes2018
Sep 01, 2021Aspirant
What a trainwreck of a design - RBS850 Satellite out of sync while wired
Added a new RBS850 to my exiting RBR50 & 2 RBS850s. Tried all varieties of instructions, most of which differe from each other. None work. Sync button, close, far away, nothing. Right now I hav...
- Sep 01, 2021
TheHolmes2018 wrote:
Someone help me with this crap or I am done with Netgear. I've invested quite a bit in other NG gear, but this is just pathetic. This is C Level design at its best.
It is not surprising that the add-on satellite has a different firmware version than the packaged system. It has what was current when it was packaged at the factory. That the existing system has not updated firmware automatically is also not surprising, although there is a raging controversy over (a) should Netgear be forcing updates on customers, and (b) whether version 4 is better or worse than version 3.
The general practice when adding a new satellite is to do a Factory Reset on the new satellite and then sync it with the existing system over WiFi using the "Add Orbi Satellite" entry on the web interface home page. Only after getting the satellite to sync over WiFi do most people move on to a wired connection.
Once it has become integrated into the Orbi system, the Firmware Update process should recognize that all components can be updated to the current firmware version.
Sep 01, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
TheHolmes2018
Interesting. I'll try this before the FW update. I have done the reset a few times already, but have not tried a wireless setup first.
The RBS should be close or far away from the RBR when doing this?
