mgpaulus
Feb 05, 2022Aspirant
What can be used as a wireless Hub/switch?
I just upgraded my RBR50 with an RBR850, and I upgraded my RBS40/RBS50 units with RBS750s. However, I have one question that I wondered if anyone has any insights into: My son's room doesn't hav...
Feb 05, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
You should be able to have the RBS in his room. IF it's kind of close to the RBR in the office, tryturning down the power output of the RBRs wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
You could try power line adapters:
https://www.netgear.com/home/wired/powerline/
However you'd still need to turn down the power on the RBR if still having the RBS kind of close to the RBR.
