mgpaulus
Feb 05, 2022Aspirant
What can be used as a wireless Hub/switch?
I just upgraded my RBR50 with an RBR850, and I upgraded my RBS40/RBS50 units with RBS750s. However, I have one question that I wondered if anyone has any insights into: My son's room doesn't hav...
Mikey94025
Feb 05, 2022Hero
mgpaulus wrote:My son's room doesn't have a wired connection, and his room is about 20 feet from the office (and the RBK850), on the same level. So, basically, a couple of walls between the RBS750 we are using as a connection point for his computer and the main router.
My concern is that the RBS750 and the RBR850, being so close together might be causing RF interference with each other.
I don't think this should be of concern. You don't need more satellites within 20 ft of each other, even with walls in between, and the wireless connected Orbi satellites work just fine. If your son is not having Internet connectivity problems from his room then don't worry about it.
